Recently added a new base. I get alerts when there’s motion but no videos in library
recently purchased Pro 2 system, installed and working for outside operation. old 3030 system removed.
i want to reinstall 3030 system as an inside operation. can i set up new account for it, or am i required to add as a new mode on the current account and change from basic service to an upgrade? if so, how can I add it and avoid having to upgrade?
The frre wya requires that you set up the new system using a second email address. Once set up, use Settings, Grant Access from the second account to the first email address and follow the emailed directions carefully.
@jguerdat I removed old base before installing new one. Used the same email address
