Recently I have been getting notifications delayed by about 2 minutes. . I used to get notifications within a few seconds of a camera detecting motion.. My wife's phone gets the notifications almost instantly but not my phone. How do I fix this?
Have you removed the app on your phone and re-installed and/or rebooted you phone ?
I removed the app and reinstalled it and it made no difference.
Laserdude,
What are the internet speeds from your ISP? What are the signal bars displaying in the app or web?
Thanks ShayneS,
wifi signal bars are one short of full. I'm usually parked about twenty feet from my router. That's where I was when the ten minute delay happened tonight. The camera that was triggered is only 15 feet from the base station.
Laserdude,
Given the number of issues you seem to be experiencing, I encourage you to continue working with the support team. I have escalated your case and an agent should be reaching out to you soon to further investigate.
As for the support, I open a couple tickets few week ago but never heard back from netgear.
Thank you for this post, was it ever resolved? I now work from home and can see the pathway to my front door. Over the holidays I noticed that when items were delivered, it was a solid 1-3 minutes before I was notified.
Yes and No - the delayed notifications never was solved and talking to support folks proved to be very frustrating and worthless with not only this problem but many others. I took one of my cameras off my system so I was back to five and cancelled my upgraded service plan and went back to basic. Doing so got rid of Arlo Smart and now my system works perfectly. It's very disappointing that nobody every owned up to this.
