  • 2 Replies
  • 2380 Views
sscotsman
Hi everyone,
I'll be going on vacation later this year, from the US to England.
I have a Verizon Android phone.
I will probably use one of the Verizon "international" plans that will allow my phone to be used in Europe.
Standard Arlo camera, the one that is just called "Arlo",
with VMB4000r3 base station.
Right now I have my Arlo sending push notifications to my phone when movement is detected.
works fine! I do need to have my phone 4G data turned on in order for it to work.
So, if im in Europe, and I have my regular personal phone, and Verizon 4G data working there, will Arlo push notifications still work normally? basically everything should be the same: Same phone, same Arlo app..The only difference is myself and my phone are physically located in England, and im using a Verison international plan with data, call, and text. I assume I will also need to keep the data always turned on there too. Will Arlo push notifications still work normally? thanks!
As long as you have full Internet access on your phone, everything works from all over the world.
sscotsman
thanks! I figured that was likely the case, but justy wanted to confirm.
Scot
