My push notifications are not going to my cell phone. I was told to go to the two-step notification and change it. I don’t see an area where I can correct the phone number back to where it was. It only allows me to change push notifications to email or old phone is there a way to correct my phone number?
7 REPLIES 7
Are you still experiencing this?
YES!!! Is there a solution???
Which version of the Arlo app are you using?
I have the original Arlo cameras. I’m not sure if that’s the info you need…? It says 4.2.5. 5758.
Is this with an iOS or Android device?
It's a new iPhone (I had no problems with my android when I had it.)
I believe the latest iOS app is version 4.3 - try reinstalling the app.
