  • 7 Replies
  • 3294 Views
Gardenut
Luminary
Luminary
My push notifications are not going to my cell phone. I was told to go to the two-step notification and change it. I don’t see an area where I can correct the phone number back to where it was. It only allows me to change push notifications to email or old phone is there a way to correct my phone number?
7 REPLIES 7
ShayneS
Are you still experiencing this?
Gardenut
Luminary
Luminary
YES!!!  Is there a solution???
ShayneS
Which version of the Arlo app are you using?
Gardenut
Luminary
Luminary
I have the original Arlo cameras. I’m not sure if that’s the info you need…?  It says 4.2.5. 5758.
ShayneS
Is this with an iOS or Android device?
Gardenut
Luminary
Luminary
It's a new iPhone (I had no problems with my android when I had it.)
I believe the latest iOS app is version 4.3 - try reinstalling the app.
