power was cycled on and off by a storm. Now system is off line. I am remote from the home for 2 months how do I reset the system remotely
Due to the power outage, there is not much to be done remotely.
You do have future options tho. 1) a wemo type outlet that can be toggled off - on to reset the base and 2) what I recommend ; is a UPS for the base and router.... ( many on site do this ) , it will keep the base online and not have the issues your going thru now.
Thanks for the input. Does the system always behave like this? There is no retention of sign-in configuration if power or internet is lost?
It seems to be a race condition. If the base becomes ready before the router, it seems like the base doesn't connect properly. Preventing the outage by using the UPS for the modem, router and base works well but a WiFi switch that the base is plugged into is an easy way to reboot the base remotely in any case.
It should happen automatically.
