  • 5 Replies
  • 1573 Views
Dghjkl
Annoying ad overlays the screen whenever i open the app.  I do not want a subscription. How do I disable this?
5 REPLIES 5
Dannybear
Easy, purchase a subscription plan.
Assuming it's a subscription pop-up, make sure your cameras don't have a zone defined in the camera settings.
Dghjkl
Super ‘helpful’. Thanks.
Dghjkl
Edit to add: yes, it is a subscription pop up.
Thank you for answering, they don’t have a zone defined.
The fastest way to clear this may be to remove the cameras and start fresh as if adding new cameras. Try it on one camera to verify that it helps.
