Has anyone experienced this issue. On several cameras, at one point, when the night vision turned on, instead of a B/W picture the picture was red. When I took out the batteries and reinserted the problem fixed itself. Now on one of the outdoor cameras the picture is once again red?
Hi lstockda,
I checked that both your base station and cameras are outdated. Kindly update them to the latest and see if the issue will be fixed.
Latest Camera FW: 1.2.2545
Latest Base Station FW: 1.4.2627
How can I trigger my Arlo system to update its firmware?
You can configure your base station to automatically update its firmware the next day. If you enable Auto Update FW (found under Settings > Base Station Settings), the base station and camera firmware will automatically update itself between 3am and 5am the next morning.
To trigger your Arlo system to update its firmware the next day:
- Log in to your Arlo account at https://arlo.netgear.com/#/login.
- SelectSettings > Base Station Settings.
- Make sure that the Auto Update FW setting is set to the ON position.
- As long as Auto-Update FW is ON and there is a base station firmware update available, the base station will update itself the next day between 3am and 5am.
- Cameras will also update their firmware on this schedule, if there is a firmware update available and Auto Update FW is ON.
If the issue still persist, it is best to contact our support to further troubleshoot the issue.
Kind regards,
BrianL
Arlo Team
I just bought a four camera ARLO from best buy on Tuesday and after installing them on Wednesday I apparently have a red screen too 😞
I've removed the batteries twice
Here is the technical stuff
Hopefully a fix is in the works.
Hello az57chevy,
I work in the Arlo Customer Support department.
I've reached out to you in a personal message to address this problem you're seeing and collect information regarding your system.
KristynM
Arlo Support Team
I have red image on one camera all the time, reset camera, still red, firmware has been updated can someone offer advise
wrote:I have red image on one camera all the time, reset camera, still red, firmware has been updated can someone offer advise
Open and re close the battery door to reset the camera, if it happens again then contact Netgear for a possible replacement issue.
The 'red effect' is not the sw update but a product of the IR filter not operating correctly.
rtechgeek,
If you're still experiencing issues with this camera after troubleshooting, I encourage you to contact our support team for further assistance.
Regards,
I was including the switch revision only because the net gear rep asked the other guy for the info... I filed a ticket with support, hopefully I'll get a replacement soon
I have had 5 Arlo cameras set up throughout my house for less than 6 months. The front camera that gets the sunrise at the beginning of the day has recently started to have a red hue. I tried adjusting the brightness but to no avail, the red hue won't go away. Please find attached a screen shot of that camera perspective. Is this camera defective? The hue doesn't go away unless it's dark and infrared takes over, but once daylight arrives the red hue returns. Please advise on how to correct
BobS wrote:This is a new installation of 5 cameras purchased and installed in the last couple of weeks.
I am experiencing the red image problem continiously in the last few days on one camera only, it seems to work in night vision mode but turns red in daylight - The camera is installed outside.
I brought the camera inside and changed the batteries and it worked correctly, as soon as I put the camera outside it was red immediately and is staying red.
I did remove the plastic film on the lens as it was clearly packaging material.
regards
Bob
I'm in the same boat. My front porch camera hasn't come out of night vision to a normal image. It's stuck on red. I had one other camera do this yesterday right out of the box but removing the batteries seems to have fixed it so far. I'm heading out to remove the batteries from the front porch camera, but as it's mounted up high this will not be something I'll want to do every day. 😞
HeatherABC,
After performing the troubleshooting steps and you are still experiencing a steady or intermittent red image from your camera, kindly contact our support team for further assistance.
KristynM
Arlo Support Team
KristynM wrote:HeatherABC,
Thanks I will. I hope this isn't a common thing because it was a pain to reset it and then having to reposition the camera. I wish there were a way to reset remotely.
2nd morning waking up to red image. Email sent to support.
In a sense, it can. You could use the pan and zoom feature to fine tune your positioning. It's a workaround at best but...
I am extremely disappointed that the return process is such that I have to send the camera back at my expense and then wait for them to ship me another one. Of course I do have the option to pay Netgear to expedite sending me another one and then I can send the defective one back at a cost of $17-30. This is a 3 DAY old system and I should not be having to pay anything over and above my $500 purchase price to have a working system out of the box. It's easier to just return the entire thing to Best Buy and re-buy it or go with another system.
Just thought I'd share for others in the same boat out of the box.
I had the same thing, paid for shipping, they sent the replacement unit FedEx ground.. in hindsight I should have sent the lot back to amazon
I don't get this company. All other companies, if their product has a factory issue it's replaced with no extra cost to their customers. I just bought on friday the 7th the 4 camera kit from BestBuy. I installed it Saturday the 8th and by Sunday the 9th one of the cameras turned red. I emailed Netgear and they approved an RMA but I have to pay for shipping it to them. OUTRAGEOUS. How could a company like Netgear not stand behind their products and do the right thing. I rather gather everything and take it back to BestBuy and give my business to someone else.
