Has anyone experienced this issue. On several cameras, at one point, when the night vision turned on, instead of a B/W picture the picture was red. When I took out the batteries and reinserted the problem fixed itself. Now on one of the outdoor cameras the picture is once again red?
I just set my system up today and have one camera that is red. Based on what I have read here, looks like I just need to go to netgear for the solution? Is that correct? i have not yet attempted to take the batteries out and reset as it is in a location that I have to pull out my ladder.
please advise.
Search is your friend. There's a zillion threads here, all with the same answer. Contact support and open a case since it's a hardware issue.
Dhx2,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Thanks for the reply....I returned my second complete set back to SAM's....I will wait about 6 months for NETGEAR to resolve the firmware issue, and then perhaps try again.
Device fw: 1.2.10342
Did you read this thread (or one of the many others on this topic)? The solutions are posted - try removing and reinserting batteries and, failing that, contact support.
DFrank, did you follow the advice posted?
Hockey01,
Thanks, I contacted support and submitted and RMA to replace the unit.
Getting tired of buying and changing batteries, starting to regret buying this system.........
I still haven't bothered changing out the one cam I had that presents red about 90% of the time . . . . . . so bothersome for something I was hoping would work well out of the box for a reasonable period of time. Had one cam give off a 'blue' tinge . . . .just once if I remember correctly, but nothing since. I am getting some odd disconnection errors the last few months . . . they pop up then just as quickly go away with a connection, and I'm getting a couple cam's having connectivity issues much more than what I had the first year or so with them. I'm just going to monitor and see . . . These cams are the only network hardware that I have issues with and nothing at all has changed in my network for quite a while now. All is indicated as a strong signal, monitoring with a separate device shows identical signal strength and performance to what was there when they were working consistently well . . .
The battery issues you have . . . . . I live in North Central Alberta and winter is cold, cold (so-so this year, but we've had cold spells this year). Anyway, I find Duracell Ultra Lithiums work for at least 2 months even in extended cold. In milder weather I get 3+ months out of them. No other battery I've used comes close to those batt's in very cold weather.
Arlo is a horrible product followed by even more horrible customer support. I have a 10 camera system and 3 of the cameras are red. I call to set up a claim with the support team and they tell me I need my original receipt. This is 2017. WHO KEEPS RECEIPTS!
Seems to me that if this product was worth its marketing, Arlo wouldnt require a piece of paper 95% of the people dicard as soon as they get home.
1  -
1  -
1  -
