Wifi netgear password. I can't get password. How can I reset password ?
Wolverine12,
If you are referring to the password for the Arlo Base Station, there is none. You simply connect the base station to your router via ethernet and then log in to your existing Arlo account to view cameras.
If you need to reset your Arlo account password, see here: How do I change my Arlo password?
I been had it work till I get new other route wifi then netgear erase password so I don't know how
Wolverine12,
Is there a phone number to call and contact someone. I have problem with the base connecting to the cameras. The base ask for me for a pasword and I don't remember. Is not the Arlo application. Please help .
You'll never be able to log into the base - that's not your problem. Tell us more about what your problem is and we should be able to help.
If you want, use the Contact Support link at the bottom here.
