Paper airplane symbol
  • 17378 Views
Armerb
Hi guys, for the life of me I can't figure out how to turn that green any thoughts?
Thank you
I haven't putzed with email notifications in a long time but it should be that you don't do anything with that. Go to Settings and then Rules. Go to the rule you want to edit and scroll to the bottom. This is where you set email addresses for notifications. Be sure to use Save twice, once for the addresses and again for the rule.
RX
@Armerb:
Is e-mail notification enabled on the rules defined on your camera?  Check this link below as reference guide:
 https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-rules-amp-how-do-I-create-them/ta-p/42
Armerb
hey!-ok awesome thank you. Completely worked!
