Resting entire system
  • 1 Reply
  • 12348 Views
Armerb
Hi guys, I want to erase everything entirely off of my system as if it were brand new again. How do I do this?
Thanks guys.
RX
You may perform a factory reset on your base station then set it all up again from scratch.
Push the Reset button (on the back of the base station) and the Sync button (on the side of the base station) for about 10 seconds or until all the LED lights on the base station blink amber. This procedure returns the base station to its factory settings. After doing a factory reset on the base station, rerun the setup procedure. The factory reset removes the base station from the account. If your cameras were synced to the base station, you might need to sync the cameras again after the base station comes back online.
To set it up and sync the cameras again, check this link: https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-set-up-and-sync-my-Arlo-cameras/ta-p/9...
