Osprey nest camera recommendations ?
  • 1 Reply
  • 3814 Views
CapeTom
I currently have a Osprey nest on a platform approx. 700 feet from my home. I need a weatherproof camera that can be POE as I am unable to access camera to change batteries while Ospey are" in residence" (six months).
The POE Q camera I would recommend but it isn't rated for out doors...
None of the other Arlo cameras really fit the need you have re the distance and/or etherent connection.
Sounds more like an outdoor POE waterproof security cam.. power and connection in one cable is needed
