I have an original base unit, and a pro base unit on the same network with cameras attached to each. Will the pro base unit record to local storage of all the cameras across both base units? Or, will it only record from the cameras attached to the pro base unit?
It will only record locally for the cameras attached to it. Those on the other base will only be found in the library.
Thank you for the super fast responce.
