If you base is offline, the remote restart button is grayed out .
There is nothing to be done without prob physical contact, ie unplug/plug the base.
There are two option fro remote locations that you can use.
1) use a UPS for the base and the router/modem ( I think this is best )... it would keep all 3 powered up and they will be happy during short term power outages ( at least a few hours with a mid sized ups )
2) buy a Wemo outlet plug...then the base gets plugged into it... Wemo works via wifi to your router so the pwoer and router must be working.
It allows you to remotely " unplug-plug "
There is a RESTART button in the settings for the base station. Try that. If you can't find it in your app, it's definitely there in the web browser
Are you able to remotely log into your modem/router?
