  • 4 Replies
  • 1189 Views
ant
Mentor
Mentor
they work well, last about 1/2 of the OEM batteries... but are easy to recharge.
I use several brands, they all work about the same.
ant
Mentor
Mentor
Half! Wow, that's not good. It's already annoying to change non-rechargeable Energizer batteries often. 😞
You can only put so much chemistry in such a small package. No truthful battery will be rated at above ~700mAH while the OEM batteries are ~1500mAH. But you don't have to keep buying batteries after the initial purchase.
ant
Mentor
Mentor
Interesting and thanks. Yeah, it is a pain in the butt to physically replace the batteries. 😞
