I just put the batteries in my Arlo. I synced it then it froze so I removed it and now when I put the batteries in my Arlo nothing happens... no blue light nothing. The other camera's that came in the box work fine. What should I do?
Verify the batteries are in correctly, if they are and are good , then you may have to either exchange at purchase place or contact Arlo support for a warranty issue.
