Hi,
I am receiving notifications from Arlo but there are no recordings in the library - I have reboot the base station and I have removed and re downloaded the app and still no recordings are in the library. Last night I upgraded to a Premier Subscription to see if that resolved the issue, but still no recordings.
Any help you can provide would be appreciated.
Thanks,
Dan
Hi Dan
I am having exactly that issue with a brand new setup. Tried using pc to setup and also the app. Everything showing me it should work but no recordings or email notification. Push notification is working fine. I was also thinking upgrading may help but obviously thats not the answer.
It must be a firmware issue as all settings are spot on.
I too am having issues with getting notifications but no recordings. Been this way for a week or better ... Removed camera batteries, resterted the base and re-synced the cameras. Still nothing. Any help would be greatly appreciated.
Mine is not working perfectly
All i did was run the motion test, light comes on camera no problem, then i saved settings and left them. a few hours later, all vidoe footage now appearing in the library.
May have been coincidence and a server issue that they fixed but either way i am all good.
I have not been able to replicate any issues with recordings arriving in the library after motion is detected.
Are you still experiencing this behavior? If so, consider a base station reboot (using the on-off button) and try again.
Please let me know if you are still having trouble,
Hi,
Like all the previous posts concerning the above, I would like an answer to this problem. I hve been following the posts on community in the hope a solution would appear.
It has been going on since early November, until this time worked perfectly. I have unistalled, re-installed a number of times, on two types of Tablets, different PC's using various shades of Linux, Widows 8.1 and Windows 10. The best I can do is a manuel snapshot, it is very frustrating considering the equipment is less than two years old.
I currently cannot not advise anyone to buy this product as it has become untrustworthy, I'm currently seeking out another viable alternative.
-David
Let me know how things worked out.
HI HeavyDMack,
Internet connection is fast enough and batteries full, went through the update procedure no luck. Firmware for the camera is 1.1.1733 and base station 1.2.1728. I notice this is differnt to the one you quote. Is it possiblr to manually update?
-David
FWIW, I have the pitiful Time Warner cable speeds of 15Mbs down and 1Mbs up. Updates are fine.
Hi HeavyDMack,
Tried all your suggestions, not happy bunny. Still does not work, So it now appears I will have dirch Arlo and waste some more money buying a different system. At the same time I certainly hope Netgear view these post, because I certainly will not be advising anyone to buy their equipment and I shall be placing a complaint to my supplier concering this product.
This problem is recent, so I believe the problem is at Nergears' end and they have done nothing too correct it.
At the sametime thank you for your help.
-Shapur
I'm currently having fisticuffs with support at the moment with an issue that seems somewhat similar since the claim is that it's the speed of the network. In my case, it's cell service rather than WiFi but slow speed is the claim to be the issue. My tests have shown that my LTE connection is as good as or better (especially in upload speed) than my cable connection. I have no resolution but it could be related somehow.
