Not detecting motion or recording
I have an Arlo and found out lately it doesnt detect motion or records any movement. I rebooted the router and still noting. Set the motion up to 100% and still nothing. Was working fine up to 3 days ago. It works great live but that doesnt help.
Stach732, dmjackson22
It sounds like the camera may be disarmed. What mode are you using? If using a custom mode, check to make sure the correct rules are set up to allow the camera to record on motion.
I am having the same issue, plenty of motion in front of camera but not recording the motion
What have you tried to fix it?
I changed the detection to 100% and increased my internet speed thinking that was causing some delays. I plan on trying more troubleshooting this afternoon to see if it gets better
Stach732 wrote:
Mine seems to be working ok now. I rebooted the netgear router. I have the motion set to 100%. The only problem that still gets me is the delay. Will try a wifi booster.
A WiFi extender won't help unless you use it to reposition the base to a more favorable location relative to the cameras. The WiFi connection between the base and cameras can't be boosted.
