Not detecting motion or recording
  • 7 Replies
  • 5000 Views
  • 5 In Conversation
Stach732
I have an Arlo and found out lately it doesnt detect motion or records any movement. I rebooted the router and still noting. Set the motion up to 100% and still nothing. Was working fine up to 3 days ago. It works great live but that doesnt help.
7 REPLIES 7
dmjackson22
Exact same challenge. I can stream but since last night my recording and motion detection has ceased. I have rebooted as well. Pls advise.
Stach732, dmjackson22
It sounds like the camera may be disarmed. What mode are you using? If using a custom mode, check to make sure the correct rules are set up to allow the camera to record on motion.
chiknft
I am having the same issue, plenty of motion in front of camera but not recording the motion
What have you tried to fix it?
Stach732
Mine seems to be working ok now. I rebooted the netgear router. I have the motion set to 100%. The only problem that still gets me is the delay. Will try a wifi booster.
chiknft
I changed the detection to 100% and increased my internet speed thinking that was causing some delays.  I plan on trying more troubleshooting this afternoon to see if it gets better
A WiFi extender won't help unless you use it to reposition the base to a more favorable location relative to the cameras.  The WiFi connection between the base and cameras can't be boosted.
