No recordings in Library
I have 1 Arlo with R7000.
All firmwares are the latest one and i am using andorid, IOS both.
Motion detection is working perfectly.
I always get an email from arlo notification.
But when I open Arlo App and web, there are alarms but no recording in library.
Actually I can see recordings via E-mail notification links. However there are no recordings in library on web and apps.
Please let me know how to fix it.
Is it my system problem? or your system problem?
Probably an Arlo server problem. Do the videos eventually show up or are they missing for days?
Ex) If i got 3 motion detect notifications, ios app and android app show me '3' on library tab. However there are no recordings. And I receive 3 notification emails, I can see motion detect recordings via email links.
YoungJo,
When viewing the library do you have a filter enabled?
As you may have noticed, we are experiencing issues with our cloud servers which may be slowing down reception of alerts and video recordings. Our engineers are working on the situation with urgency and things should be back to normal shortly. In the meantime, we apologize for any downtime you’re experiencing and want to let you know that we are working non-stop to address the issue.
Update:
A fix for this issue has been released and has significantly improved Arlo performance. However, a side effect you may currently experience is the alert counter on the camera screen disabled and set to 0. Resolving this counter issue and further optimizing Arlo performance is our number one priority at this time and Arlo engineers are working non-stop to resolve this.
Please refer any additional comments on this issue to the following thread: https://community.netgear.com/t5/Motion-Detection/Email-Alerts-Video-Recordings-Not-Getting-or-Getti...
Thank you,
npk200189,
Could you provide more detail about the issue you are describing? Are you saying you can view content in your library using the Android app but that same content is not visible when using the iOS app?
Check to make sure no filters are set when you are viewing the library. All content should appear in the library regardless of the client you are viewing from.
npk200189,
Please private message me the case number you have open with the support team and I will take a look. I will provide any additional feedback that I can.
Thank you,
Manual recordings normally exist in library with current date and time.
However motion detect recordings are not showed in library. Because when I checked email notifications, recordings date were 1 Jan 2015. What is the problem? I think It is Arlo netgear cloud server problem. That is why I can see recordings via cloud server link, cannot see in library.
Please fix the recording time and date issue.
YoungJo,
Motion detection recordings are stored in the library along with manual recordings.
Have you tried viewing your library from a different device to further isolate the issue?
ZhongZh,
What firmware is your base station/cameras on (Settings > My Devices > select base/camera > Device Info)?
Outdated firmware could be the reason you are having issues. Please be sure that the latest firmware is installed and try again.
