No or unreliable cloud recording the last couple of days.
Anyone else have issues with cloudrecordings the last couple of days? This is really annoying and it is the primary reason I bought Arlo. It has worked without a flaw for the last 5 months ( and caught a couple of burglars) but suddenly recording is intermittent of unreliable. According to the The status page everything is working without a flaw...
What is going on??
Br
Thomas
Yes, my cameras have been doing the same; as part of a custom Armed routine, triggering motion detection on one camera should result in another 3 cameras recording. This has been haphazard at best for the past few days.
I have some scripts that pull the recordings down and combine them into a 4-panel security screen-type video but this continues to fail because either the Arlos aren't uploading or they're not recording at all. Comparativly my Ring cameras have been pretty flawless.
I am now forced to return 4 additional Arlo cameras I bought as support appears to be non-existent.
