I installed the system today, and first synced one camera. It worked perfect. Then I tried to adhd a 2nd camera. I follow the instructions as for the first, but the camera didnt show up. Then I resetted the camera (powercycling), and tried again. Negative result, again. Then I restarted the basestation, pushed the synd Burton and powercycling the camera. Then the camera showen up, but there is no picture avilable. Also I notice that the camera has taken abort 10% of the power in the battery during only 2 hours.
I have reseted everything and done a faktory installation, but now my ideas is drained.
Tor
Hi again.
Did go back to the shop where I bought it, and they exchanged the camera. The new camera started at once, and gives perfect picture, so it was a HW fault on one of the cameras.
Again, thanks for support here.
Tor
Have you tried to swap batteries with a working camera or insert new set of batteries?
Have you click the live button to see the camera in action?
Hi,
Yes I have changed the batteries, and tested with live camera, but no picture. It has connection to the Basestation but does not show a picture. So, first camera is working, second gives no picture. It detects motion!
Apriciated your support here.
Tor
Hi again.
Tor
Thank you for sharing.
