I'm not getting a live feed from the App. Restarted base station. Removed camera and reinstalled. Doesn't change anything. Tried being in the same network and not.
Have fibre optic internet connection with above 35mbps consistently.
Really need help or I'll be sending this back.
Have you tried a browser?
I haven't.
As the set up pointed me directly to the app, I have been following that.
Is it through the 'My Arlo' area on the web?
Ok just tried it.
Doesn't work on the app, through Chrome and Firefox and either i get 'The camera failed to connect. Try again' or the screen goes back to the 'Live' button or 'Unable to play. Please try again'
Flash is enabled also.
Check your firmware versions in Settngs, My Devices for each of your devices and compare to what's found in the Release Notes section here. Old/mismatched firmware will do weird things. You may need to reset the system by removing all devices from Settings, My Devices and start fresh. Use the Add Device button to add the base and sync the cameras. If prompted to do firmware updates, do so.
But will try again.
Will come back to you tomorrow. Fingers crossed it works...
Removed and reinstalled both the base system and camera, rechecked login via the app, firefox and chrome and i'm getting the same messages.
I'm at a loss now...
Swap the system at the store or open a case with support here.
