No Pan and zoom image is displayed.
  • 20 Replies
  • 9864 Views
  • 2 Likes
  • 9 In Conversation
Llewxam
I purchased an additional camera today and I cannot get it to post a pan and zoom image for me to work with. I've tapped the camera at the top right, tapped the screen, and rebooted the base several times. No luck. Any ideas for a fix?  Thanks.
Llewxam
Issue solved!  Thank you Arlo. Good work!
20 REPLIES 20
mep123
https://community.netgear.com/t5/Troubleshooting/APP-Camera-Setting-Pan-and-Zoom/m-p/618#U618
Does Netgear monitor this forum? Several of us are having the same or a similar issue.
We are aware and are currently investigating the issue with the pan and zoom feature. The zoom feature when live streaming and manual snapshots are working without issue. We will provide an update when we have a resolution.
mep123
Fair enough.  Thank you, sir.
Llewxam
Update:  Just for the heck of it I returned the camera that I was experiencing the pan/zoom dislplay issue.  I sync'd the replacement camera and still have the same problem, no pan zoom.  I did notice, howeve, the camera at the upper right is not available on my Apple computer but is available to use on my iPhone;  never the less clicking the green camera still did not activate the pan zoom feature.
Jo
When I first got the system the pan and zoom worked fine.  Attempting to adjust one of the cameras had lead me to discover it no longer works.
devotchko
Luminary
Luminary
manual snapshots (tapping or clicking on the camera icon for an individual camera under the settings page) does not work for me. I have the latest software, and I have already tried rebotting the base and the router several times...
Deckard4150
Any update on the pan and zoom not working? I purchased my cameras on 11/21/2015 and I am having the same issues. I rebooted from the PC and from the base station with no change.
Llewxam
Hi - thanks for your question. You have done everything that I have done that can be adressed from a users perspective. As far as I know Netgear/Arlo has yet issue an update to correct the issue at hand.
Our engineers have tested and resolved this issue and plan to deploy the fix as soon as possible (likely today or by the end of tomorrow). We appreciate your patience and understanding in this process.
Thank you,
Just tested this and it's working fine.
Llewxam
Sasnak79
I'm having this same problem with one of my cameras. Can someone please tell me what the solutions was?
Thanks.
App or browser?  Have you tried the other?  Sometimes logging out and back in clears the issue.
Sasnak79
Actually, I'm having trouble with both the Android app and browser. But I'll focus more on the Android app. The screen capture image on the left below shows the pan & zoom section on the Android app for one of my other cameras, which seems to be working correctly. But the screen capture image on the right shows the problem camera. Notice that the camera icon on the right side is grayed out, and on the left side of the image is the spinning circle, which never goes away. What started all of this was when I was in the browser I selected the green camera icon, but after a minute or two the icon came back as green, but the camera image did not update like it does on my other cameras. So I then opened the Android app and that is shown below - I can't select the camera icon, and not only that, but my battery charge suddenly went from 90% down to 25% by the next day. Thanks for the help.
I would power cycle the base and open and close the battery door on the camera.  Any luck?
Sasnak79,
To add to what jguerdat has suggested above, if you are still having issues after rebooting the base/camera, consider remove the camera from the system (Settings > My Devices > select the affected camera > Remove Device) and then go through the sync process with that camera again.
Please let us know if you are still experiencing this issue,
Ponch1965
I seem to have the same issue upon new install of a 6 camera system (2-Q's and 4-wireless/base).  All camera's function correctly for motion detection, alerts, etc.  Only one camera has the issue.
I have one camera (wireless) that is stuck on the original image when you look at settings/my devices/<camera name>.  Read through the forums, reset base, removed batteries from camera, removed device, resync'd, cleared cache and data on phone app, tried IE, chrome, firefox, and IOS app.  From the app, if I click on the camera, the spinning disk never goes away and image is blank - even after a clean re-install of the application.  From a web browser I can see the original image, take the snapshot, or try to zoom the image of the old spot and that will simply wait 20 seconds and return to the original image with no zooming or panning on the image.
If anyone has other suggestions I would be interested to hear them.  I'm a systems administrator with 20 years of troubleshooting and field experience so feel free to be technical 😉
Thanks for any suggestions in advance,
I'd suggest contacting support using the Support link at the top here.  It may be hardware, not software.
Is that technical enough?  😛
Ponch1965
Thanks for the suggestion, I did open a case as well.  Arlo/Netgear support was responsive within a few hours to at least make a few suggestions, so that is a good sign that at least they care about the product.
I will report that overnight the issue seems to have corrected itself.  I can't explain why, but coming from the I.T. world - never question success.
Perhaps some good advice would be to sleep on it before jumping on the forum 😉
