Nighthawk X4 R7500 with Arlo
Hi all,
i've one Nighthawk X4 R7500 with the latest Firmware 1.0.0.94 installed. Also a Netgear WNDR3700 Rangemax to extend my WLAN to the basement.
On both of my Netgear Routers i'm not able to connect one of my 4 ARLO-Cams.
Everbody an idea how to connect because i want to eleiminate the Netgear Basestation VMB3000.
Thanks in advance,
Guenter
There is no router anymore than supports direct connection with the Arlo cameras...you must use the base unit
