Arlo wireless flashing LED when motion is detected
how do I disable the flashing LED when motion is detected
If you mean the Led for testing in Motion, just exit out of the section....
If the led is flashing after, you can always reset the camera by opening and closing the battery door ( you shouldn't have to resync )
Ronaldk1,
To further clarify what TomMac is describing, there is no LED that flashes during a normal motion detection event. The flashing LED on motion only occurs in Motion Detection test mode.
