- 2
So far nothing but positive results all around and up to this point with this product. I installed my new Arlo 2 camera set up today, followed the instructions to the T and enjoyed all day views. Heres the problem - once night fell I went to check and see how the cameras look at night. Low and behold, the front door was camera was working flawlessly and the infrareds where working when viewed... But I noticed the back door camera was not. The camera is on and working, but the infrareds were not showing in "Night Vision" like the front door? Can anyone give me a hand with the second camera, I would love for it to work like the one at the front door if possible.
Here is a screen capture of what I see. The image on the left is camera at the front door (Infrareds on and working) - the one on the right is the camera at the backdoor (Camera is on but no Infrareds working so its pitch black)
Lots of info on contacting support? My wife just spent and hour trying to figure out how to contact support. I spent 2 hours this morning. No body w ill chat, noone until you responds to email and no phone number is listed in spite of a "call us" at the bottom of page. What is the phone number? Why won't one of 2 cameras function at night?
This worked for me as well! And after I disabled, I went right back and re-enabled pan/zoom and it worked just fine. This is just my first day with the camera, hopefully it will continue to work as expected.
Hi just having issues with constanct notifications at night and am trying everything to get them to stop. I noticed this post about disabling pan, zoom and tilt but am unable to find anything on how to do so. Can you walk me through the steps on disabling pan, zoom and tilt please??
Did you ever get your issue with notifications resolved? If not, is it Push Notifications or Email Alerts (resolving both is a similar process)?
When my night vision stopped suddenly... I tried going into the app and turning off the camera for a minute or two.
I the signed back in, turned the camera back on....went into video settings and turned on NIGHT VISION..
It worked!!!!!
Hope it works for you...
Thanks for pan and tilt advice. Reset this and night vision worked perfectly. How annoying.... stupid design.
MJK1959 wrote:Just got off the line with support. Disable pan and zoom and viola...night vision works great.
Really? Still working ok after that chnage? Mine seems to work after i reset batteries but then a few night later it's back to the black screen.
paulwicker wrote:Really? Still working ok after that chnage? Mine seems to work after i reset batteries but then a few night later it's back to the black screen.
Same for me. I ended up just changing out the camera with the one I have inside the house. I literally have spent hours and hours (at this point all probably adds up to a day or two) trying to correct the problem. The camera I put in its place has worked fine with no issues (knock on wood) which leads me to believe it had NOTHING to do with what Support orignially said which was the "Upload Speed wasn't sufficient". I have a total of 5 cameras and this is the ONLY one that does this. This is also why I exchanged the first set I bought last November. So annoying.
- 2
