i use a verizon netgear for internet-how do i connect the camera to this system. when i try it asks for network security key
If they were out yet, we'd prob have an answer...
I think you should contact Netgear directly
If you not talking about a GO, then there is no direct access to the Arlo bases, they must be connected to the internet via ethernet cable to your router.
