  • 3480 Views
FrustratedwNG
Hello.
My netgear base station won't turn on. I have checked to make sure the power button is on and it is. I have turned it off and on but that doesn't do anything.
I also went to a different outlet and plugged it in but the power light does not go on.
It seems like it is dead. What else can I do?
Thank you.
Streak2
Master Master
Could be a faulty power supply. Do you have another 12v power supply that you could test with? Or another device that uses 12v that you could test the Arlo power supply with?
FrustratedwNG
I will buy a 12-volt power supply and see if that does it.
Make sure it has the right current capability and polarity (check the existing supply for details). ALso open a case with support here since that's the only way to get faulty hardware replaced under warranty.
