Wireless Camera Will Not Sync After Changing Batteries
  • 1 Reply
  • 1134 Views
Flashfox_Prime
OK ... I read MANY posts with similar problems and I tried all but one.
- I have 5 cameras
- One camera's batteries ran out so I changed them
- I changed the batteries but the camera never synched automatically like the others
- I tried the suggestions I read over here and am still unable to sync it, so as also suggested, I removed the camera
Result - I cannot get the base to see this camera (used the Android app, the web interface and just the base & camera)
What I did:
- Pressed the base sync < 1sec
- Camera LED on the base blinks
- I placed the camera ~6 inches from the base
- I pressed the camera's button once (<1 sec ... I also tried 2 seconds)
- Camera LED flashes at ~ 1 flash/sec
- Nothing happens .... no sync, nothing. By the way, the camera's LED continues to flash at ~1/sec, it doesn't stop, even after over 15 minutes.
- I tried this several times to no avail
Note that I opened the camera's battery cover between each try to make sure it was starting fresh.
My comment: This is crazy! ... the only thing I haven't done is a full reset of the base as it means that I need to get all of the cameras and resync each one, which is a pain as to where they are located.
Question 1 - Is it normal that the camera's blue LED continues to flash now after 20 minutes?
Question 2 - Is the only way out to reset the base and start fresh?
1) No, not normal.
2) I don't know it will fix anything but it's about the only way left.
