Is there a Arlo Outdoor Power adapter that will work with this Netgear camera so I can plug the camera in to the electrical outlet next to my Netgear (Arlo) camera? Not sure what model camera I have, maybe ArloVMC3030-100NAR Security Camera? Camera was installed outdoors in August, 2017 by a security Company. The word NETGEAR appears on outside of both sides of the Camera. Can you recommend an Outdoor Power Adapter that will work with this NETGEAR Arlo model camera?
Does your camera also use 4 CR123 batteries?
There are some third party ac feeds for the Arlo HD cams, but not from Arlo.
You would have to do a web search
like this, Power Adapter with 16 Feet Cable, Plug Adapter Compatible with Arlo Camera (VMC3030, VMS3430), Replace CR123A
