Strange thing just happening within the past hour...
No ARMING ICONS appearing on the live view screen and no battery icon on two H11 arlo cams....
Reset base, no change... Not on my end. Anyone else ?
ON PC, will chk ios and android
All fixed... don't know why, didn't do anything...glitch some where, Fire Fox issue I would guess.
Further test show all working well on IOS and Android...
Also on Win EDGE.
Looks like it's just related to Fire FOX for some reason ( all working, just no little running men on or off )
Ok.. tracked this down ito an issue with the latest version of Fire Fox and Arlo ( prob more FF )
It seem if you use a reduced size screen ( I use 80% to see all my cams ) with the option " ctrl--/+" the Arlo browser does not populate the Arming icon and sometimes battery icon.
If put in 100% screen mode the icon will reappear.
