We have not received e-mail alerts since 12:09pm PST February 18, WHY??????? We signed up for e-mail alerts and want them, why did they stop?
Thank you for any help.
TAZZY
TAZZY,
I have tested this and was able to receive an e-mail alert when motion was detected. Please check your active rules for your cameras to make sure you have email alerts enabled for each camera you wish to send e-mail alerts. Please let us know if you continue experiencing this issue.
Thank you,
No, I have not been able to activate the cameras. I do not find anywhere where it says "active rules," We had everything setup to work and all worked fine until a problem on your end disabled all four camera e-mail alerts! We loved our cameras but not happy at all now.
TAZZY
You're not giving us enough details to work with. For starters, use the Mode tab, select your system and edit any modes you have (not the schedule - it's just a schedule). In each of those modes, other than the Disarmed one, you have the ability to change your settings, including email notifications. If you make changes, be sure to use the Save buttons as you go. Once those are set, go back to display all your modes - one has a green button on the left, indication that it's active. If you want a different one, like Armed, click that empty button so it becomes green. If you now look on the Cameras tab, the running men should be black, not gray. Once you have things configured, consider setting up a schedule so it's hands-off.
When did you create your All Motion On? That was the name of the old default mode that Armed has replaced. There have been many reports of old modes being carried over after the update at the beginning of the year not working properly. I'd recommend creating a new mode with all the same settings as All Motion On and then delete All Motion On. It's likely that it's the old mode being one of those that don't work properly for whatever reason.
