how do i check the camera on the cloud. i cant get to the website it wont load
5 REPLIES 5
assume you're using your pc.... which browser are you using? |Have you tried one of the other browsers?
i though chrome would work. i had my smart phone and kindle stolen so i have to use this old lap top. is chrome going to work or is there a different issue.
i think someone else mentioned a chromebook doesn't work but chrome on a pc did. but could be i remember it wrong
Supported browsers are Fire Fox, Chrome, IE>v10
all must have flash
Make sure the OS and browser are up to date. Old versions may well cause issues.
