  • 5 Replies
  • 4108 Views
Tucsongram
Are there instructions for the Outdoor mount?  I need instructions.
Find a good location for the mount
screw the mount down at the base with 3 screws till secure
screw camera onto threaded end ( into camera)
tighten small knurled knob so camera is lock in place
loosen big wing nut to rotate camera into proper view
tighten large wing nut
done
5 REPLIES 5
done
Tucsongram
Thank you!
Cmillett
If I screw the camera to the correct angle and the tighten the white thing, will it hold the camera securely ?
That should be the locking nut so, yes.
Cmillett
Thank you so much. I had a horrible feeling of seeing the camera go splat on the cement. Thank you again for being so speeding with responding!!!!!
