Why does the my.Arlo website keep timing out?
Always has as a security issue (walk away from the computer while logged in). Doing anything on the site resets the 30 minute timer.
Sarahpattan, Bthomasmo
Is the behavior the same on both the Arlo mobile app and the web client? Are you able to provide a screenshot?
This is the error I get even though I click it within 5 seconds of opening this tab.
Thanks for the screenshot. (removing as this is a public forum and I don't want any of your sensitive information exposed).
Are you trying to share access? If so, try accepting the link using a PC to see if you still experience the same issue.
