My VMB3500 HUB is online and green but cannot be discovered from my Arlo app on my iPhone. HELP!
My VMB3500 is online and green but cannot be discovered from my Arlo app on my iPhone. HELP!
christen27,
Is this a brand new base station or was it in use prior to you trying to onboard?
It was hooked up at my old home with older cameras. I moved into a new home and bought new cameras yesterday and now it will not hook up.
Christen
christen27,
Log into your Arlo account and check to see if the device is present under Settings > My Devices.
If it's not listed, try manually factory resetting the base station and then go through onboarding as if it were new. For instructions on how to do this, see here: How can I factory reset my Arlo SmartHub or Base Station?
