My Batteries tend to go down then when i open and close the battery door they go back up in power
My Batteries tend to go down Like 14% then when i open and close the battery door they go back up (Like 60%) in power again? all updated and all, just seems werid? they are teh ones that came witht eh cmas been working fine for months..
While it's possible that the software is giving an incorrect reading, it's also possible that the batteries aren't touching the contacts in the camera properly. When you insert the batteries, don't push them down. Let the battery door do the pushing. This is because the cameras use the batteries as two sets of two, front and rear, and switches between the sets. If one set isn't making connection, the other set gets used exclusively. Opening and closing the battery door may be allowing the second set to get connected, giving you that strange indication.
