My Arlo wireless cameras are stuck on "Getting Status" when I log on to view. They never goto "Live"
I have one Arlo Q and 4 Arlo Wire-Free cameras hooked up to the same base station. All have worked just fine until recently when the Arlo Q pops up to "Live" when I log on, while the remaining Arlo wireless cameras are stuck on "Getting Status". Thats as far as they go, never changing over to "Live" option. I have restarted the base station several times and all 4 Arlo wireless units have brand new batteries. Thanks in advance. Jeff
Same here !I have 4 wire free cameras and 2 Arlo Q,
it started last night, all the arlo wire-free cameras have gone dark with "Getting status..." on the screen. but arlo Q still working.
if runs out battery, they should not run out at the same time, as all 4 of my arlo Q have battery from range 30%--65%.
Is there any one could help us please ?
Thank you in advance
Naomi
Tracy
I'm not having any problems. Have you tried both the app and a browser? Does one work?
Both the app and browser do the same (Arlo Q connects just fine, but not the wireless Arlos), but the message is different. My browser says "Failure to connect" while the app says, "Getting Status"??
Consider rebooting your base station using the on-off button. Allow the base station to come back online with a solid green power and internet LED. Are you still seeing the same behavior?
Tracy
