I have reset the system but still shows as video taken but no video shows + there is no one to contact via phone to help with this .
I see other poeple have had this problem and I'm not sure if its been fixed. Please help.
thanks for the info turns out it was a date issue , just had to click on the time zone and reset.
5 REPLIES 5
How diid you reset the system ?
Also, check on your SW versions asgainst the release notes to confirm you have the latest.
if you've been checking on your phone, try checking on your computer; if checking on your computer, try using a different browser
Where is the support for this issue?
thanks for the advice
