If I click on the Modes Tab in my App on my Pixel2 phone, multiple Armed and Disarmed modes show up then recording and therefore notifications stop. I've tried reinstalling my App but that didn't fix it. After an install, as long as I don't click the modes tab, my cameras record fine, I can see the videos in my library, and I get notifications. Has anyone else seen this issue? I want to get the new 1080p cameras, but I need to wait until I can fix this issue. I first noticed this on 9/15/18 I think.
What happens if you use a browser? If it's essentially the same thing, cut bait and start fresh. Remove all devices in Settings, My Devices. Use the Add Device button on the Devices tab to claim the base. Sync the cameras. That should get rid of any weirdnesses.
It looks like removing my base station and all cameras worked! I also uninstalled and re-installed the app on my my phone. I was a little skeptical that it would work because the cameras came back with the custom names I gave them instead of the defaults. There was infromation about them saved somewhere. But, after going into "modes" on my app, it no longer lists the multiple mode names and my recording and alerting is still working. I will keep watching this for a week or so to make sure nothing changes, then maybe I will go get some new 1080p cameras to try them out.
Thanks for this suggestion!
