  • 5 Replies
  • 18715 Views
  • 5 Likes
Jrullo
Hello, I am looking to see what the best solution is for mounting an arlo & alro pro camera under the eaves/soffit of my home.  In my situation, I feel this is the best location for my outdoor cameras.  Whats the best way to mount the arlo's to the eaves/soffit using the outdoor mount?
5 REPLIES 5
Using an outdoor mount, like below, you may have to invert the camera ( toggle flip view in settings so it appears corect )
cam mount
But before you go mounting, see if you can temp mount ( duc tape ?) and make sure the location/view is good
Putting to high and you see head tops only
Jrullo
Thanks, I have the outdoor mount you posted below.  I was just wondering what the best way is to fasten it to the eaves/soffit since it is vinyl and it is hard to find the studs/roof framing to mount to.  For some reason, it is not easy to remove my soffits to determine mounting location.
The location where I want to mount a camera is not too high off the ground, but high enough that no one can reach it (probably about 12 feet).  I will defintely test the location before permanently mounting.
I just want to hear what folks have found to be the best solution for mounting it under the eaves/soffit for others out there.
Chillmiester
Luminary
Luminary
I have mine mounted under the soffit in the backyard and it works fine and can't be reached. I use the magnetic mount so it will be easy to remove and charge for the reason at times I monitor the dog in the backyard.
Jrullo
How did you attach it to the soffit?
Most homes would likely have wood under any siding so just use a "long enough" screw. I'd think a 2 inch screw would handle most situations.
