I have these cameras work for a few months and then something happens. Get them working again and a few months later something else goes wrong. Sucks to get to a camera 10' off the ground that is already set to view a certain area down into the house and re sync every time.
Bad update?
Maybe try restarting your base station.
When you say "something happens" or "something else goes wrong", what is happening/going wrong?
I wish that was it but I have already reset the base.
I just keep having problems. Motion not detected was an issue, then the the video color was orange and green, then it could not update and I had to spend another $35.00 a month for faster internet.
Now it detects motion but only records some times.
I have only had them for a year. Worked great in the begining.
felt like I had a piece of mind and was safer with the cameras, well not so much now.
What firmware versions are your base and each of your cameras on?
2.4.2_17124
1.2.10342
This is in the Arlo Go section but you seem to be using an original wireless system (not the Pro). You also posted the app version rather than the base. The camera is up to date but the base should be 1.8.8.0_11528. You can always check your versions against the latest released in the Relese Notes section here.
