I also keep getting Arlo is currently unavailable message on one system while the other system works normal.
Thanks in advance for any help.
Thman,
Camera position can be a factor in motion detection performance. It can sometimes take some trial and error to find optimal conditions for your Arlo system.
Take a look at the tips in this article to be sure your cameras are positioned for best performance: How do I optimize my Arlo Wire-Free camera’s motion detection performance?
The porch camera has recorded everything from racoons, cats, sales people to the occasional wasp, however when I received a large package from ups (approx 3'x5') delivered in plain view of the camera....literally less than 5 feet away and had no evidence of the delivery in my library I started to wonder how much motion I'm actually missing. I've noticed this several times before but wrote it off to someone walking by too quickly or the motion sensor sleeping a little to long.
After reading thru many of the other questions and answers, I'm thinking this may be a common issue that has happened recently.
Mine is doing the same thing. I had an employee come to our office while closed and the only video it caught was her entering the back door inside the building. The cameras outside didn't capture anything. We have had a lot of fog and moisture in the air. Maybe that it the problem? I went outside and did a motion test on the porch camera and found that it didn't work unless I was right up on it. I've never had this problem before.
carissahamilton,
It could be an issue with the position of the cameras causing the issue you describe. If you (temporarily) relocate the cameras, do you see the same behavior?
