Is anyone else having problems with their cameras detecting motion? How do we contact Arlo? Mine also keep going offline & I have to resync. Very frustrating!
Have you tried changing the motion sensitivity to see if that helps? You can read here on how to adjust that: How do I change the motion sensitivity on my Arlo camera?
And feel free to use the motion detection test to make sure that your camera is detecting motion, which you can read here on how to use the test: How do I use the motion detection test for my Arlo device?
Hi Dana-NP,
If your Arlo camera is not detecting motion properly, try to remove the batteries from your Arlo camera and re-insert them back in to see if that helps. You can read this article to learn how to troubleshoot if your camera goes offline: My Arlo wire-free camera is offline; how can I troubleshoot it?
If that still doesn't help, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
For some reason when I have tried to do the motion detection test it just spins and spins and won’t pull anything up. I’ll have to follow your link to see if it works any differently.
Thanks again,
Dana-NP
Glad to hear that helped out! Feel free to let us know if you still have any problems 🙂
