I recently change the batteries on my Arlo wireless camera. Afterwords the motion detection function stopped working. I took out the battery several times without results. I disconnected the camera from the system and reinstalled and it still does not work. Any ideas?
Message 1 of 4
1,955
I have been able to turn the camera on and view as well as record. I also tested the motion detector and the amber light flashes as it is supposed to. However motion will not trigger the camera. I have not tried checking the active mode and rules which I will do. Thank you.
Message 3 of 4
1,926
Can you live view and manually record? Have you checked the active mode to verify the rule for the camera is present and has an action of recording? All details are useful.
Message 2 of 4
1,931
Message 3 of 4
1,927
That seems to have worked. Thank you for your help
Message 4 of 4
1,919
