That's your problem - the test is just a test. It gives you a number to be translated into your modes. Read the FAQs here on what modes/rules are and how to set up and change them. Basically, use the Mode tab, click on your base and edit your modes. Right now it sounds like you will just have the Armed mode which you can modify to a point but I'd suggest creating your own custom modes, using the Armed mode as an example. All settings are in there, including the motion sensitivity setting where you use that number from the test. Be sure to save at every opportunity.
To be clear, you're changing the motion sensitivity in your modes and saving, right? The motion test doesn't save anything since you might have different modes with different settings.
Thankyou for all your replies, when I tap on my base I have the option of armed, disarm, schedule and geofencing, with the option to edited those, when I tap on edit I only have the option of either do nothing when motion detected or record there is no option to set any sensitivity . I will look on FAQ in meantime awaiting some more replies from this, ps I have tried to upload some screen shots but the photos tab above doesn't seem to load properly it cuts out the bottom of window where I assume the load button is!
You stopped too soon. There's an edit icon to the right of the Motion Detected selection - click it so you can edit the sensitivity.
