Has anyone else had this issue? Because they won't delete, there are 50+ modes that show as options.
Any help would be appreciated. Thank you.
Jason
Had to painfully re-connect the base station and all cameras, as well as re-configure my modes.
Wow! Strange!!
Is this with both the app and browser? Can you delete them using one but not the other? You may need to remove all devices in the settings tab, factory reset and start fresh. PITA bit it may be your best option. Screen capture or write down any settings/info before you do this to ease the rebuilding process.
Good suggestion!
i checked he modes via web login, only shows 5 modes. I've been viewing through the app till now. I tried deleting and reinstalling app, still shows 50+ modes (same default modes over and over) that still cannot be deleted.
so it seems like it's an app issue?
not sure how to fix that though.
Are the 5 visible modes in the browser still including multiple Armed and Disarmed modes or are they different? If they're still multiples, I'd do a factory reset which will clear everything out and give you just the default modes.
I might just reset the whole thing in hopes it all gets fixed. But so far, it's just affecting the arlo app itself.
