ModelVMS53330C - Do I have to re sync cameras after a power outage due to Hurricane Irma.
  • 2 Replies
  • 1857 Views
sac17
Base station shows disarmed and Arlo no longer sends detection to my cell phone.
It sounds like you simply can't access the system after a lengthy power outage. Assuming your Internet is working, try turning off you rmodem, router and base and then turn them on again in that order, allowing each to initialize before going to the next. Your batteries in the cameras may be dead from trying to connect to the base that was off so be sure to use known good batteries.
Worst case, reset the system by removing all devices in Settings, My Devices. Use the Add Device button to add the base and sync the cameras (again with known good batteries).
sac17
Thanks for the help. It turned out my base station was disarmed and that was my problem.
I did do what you suggested and found out what my problems were.
